Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 6th Gen Discussion > 6th Gen Suspension
Old 05-28-2008, 09:40 PM   #1 (permalink)
baybullyz's Avatar
i need to center my rear wheels
what do i need to do to center the rear wheels
baybullyz is offline
Sponsored links
Old 05-29-2008, 07:10 AM   #2 (permalink)
Heavy_SS's Avatar
get some new rear suspension from Hotchkiss. I believe the car needs new longer trailing arms.
Eric Iverson
96 BBB SS
51 k and counting.
Typical newbie mods, with no gas in the tank.
www.minnessota.com
Heavy_SS is offline
Old 05-29-2008, 08:56 AM   #3 (permalink)
KW Baraka's Avatar
Originally Posted by Heavy_SS View Post
......I believe the car needs new longer trailing arms.
Yes......Extended Control Arms.....several vendors and brands:
http://www.google.com/search?hl=en&i...SS&btnG=Search
Suggest that you install an extended driveshaft, too.
Due to cost of this mod, you might also ask;
"What's it worth to me ($$$$) to do this?"
KW
1996 Impala SS and 1995 Caprice 9C1
KW Baraka is offline
Old 09-13-2008, 06:50 AM   #4 (permalink)
406IMPALA's Avatar
i would have to say hotchkis has the best kit and its about $600 and if im not mistaken you do not need to get a longer drive shaft, it will also help you launch better and look better
406IMPALA is offline
Old 09-14-2008, 10:38 PM   #5 (permalink)
maesstro's Avatar
All of the above are good suggestions, unless he's talking about centering them "left to right" as opposed to "front to back." And, just to be an Ass, you don't "need" to center your rear wheels- you "want" to.
I suggest following KW's advice and figure out the total cost involved of both extended upper and lower control arms and driveshaft, then asking yourself if it's worth it.
Some people will tell you with the Hotchkis kit you don't need an extended driveshaft, since it's just a 1/2" extension compared to most others 3/4", which does require an extended driveshaft, but I would have the money for one on hand, just in case.
maesstro is offline
Old 09-16-2008, 08:22 PM   #6 (permalink)
impaladreamer_30's Avatar
why aren't the wheels centered anyways ???
it there a reason, or did GM mess up and didn't want to fix the problem
impaladreamer_30 is online now
Old 09-16-2008, 09:41 PM   #7 (permalink)
Supporting Vendor
MikeT's Avatar
The Hotchkis kit does not require a longer driveshaft. You will not need to address this UNLESS there are other extenuating issues or problems.
FocuzTech Performance
||Performance|| Service||Technology||
Complete line of performance Parts and Accessories
On the web: www.focuztech.com
Telephone 425-427-6690
Email: sales@focuztech.com
MikeT is offline
Old 09-17-2008, 08:36 AM   #8 (permalink)
hey hey !!!
i would like my question answered too ....
i'm just curious ......
Old 09-17-2008, 01:17 PM   #9 (permalink)
maesstro's Avatar
The wheels are not centered front to back because the SS is based on the earlier caprice design, which originally had wheel skirts. When they removed the wheel skirts, it makes it appear that the rear wheels are shoved forward, though from what I have read, they are actually centered in the wheel well, just not the wheel well opening. You can push them back either 1/2" or 3/4", depending on which kit you get, but it does alter your suspension geometry.
Many peoples wheels are not centered left to right, well, because GM screwed up drilling the holes for mounting the upper control arms. There is a TSB out that elongates those holes so there is enough play to center the rear axle left to right, but that is a piss poor effort to fix the issue. Elongating the holes will just allow the mounting hardware to slide around in the hole, and since the hardware is probably made of a harder material than the frame, will just make the hole bigger over time. Some people have had success loosening or undoing some of the body mounts (which is another issue entirely for the SS) and sliding the body over to center the wheels.
maesstro is offline
Old 09-17-2008, 01:21 PM   #10 (permalink)
there we go ......
Thanks for clearing that up for me ...... i appreciate it
Sponsored links
vB code is On
Need to know how to center my 22" wheels. front and back QuestFor Speed Wheels and Tires 2 04-24-2008 05:56 AM
eXTReMe Tracker
Sitemap Index - Archive
