frontshock mounting question
I swapped in new shocks up front this morning. The FSM was of course a big help (NOT). It says to torque the top nuts 97 ft/lbs.
I ran the nuts down until the shock shaft starts to turn as well (bushings compressed). FSM says put a wrench on the top to keep the shaft from turning but 1. the flat sided on the top of the shaft only fits 1/4 open end. 2. I can't figure out how to get a box wrench on the nut to turn it while hopefully holding against the grain with a little 1/4 wrench (I tried) I also tried putting a short box wrench over the nut and tried to turn with the 1/4 inch wrench but can't get the torque to turn it..... What a PITA. I got the old shocks out by using a vice grip on the shaft, but don't want to do that on the new ones! any ideas? |
| Sponsored links | |
#3 (permalink) |
I would try a 6 point 1/4 socket and ratchet or a 6 point wrench to hold the shaft while you turn the nut.
1977 Impala Sedan, 5.0L, TH200R, 3.25:1, 74K miles, 26 Lifetime Warranty Parts. 1997 Dodge Ram B2500, 5.2L, 36RH, 3.21:1, 335K miles, 6 Lifetime Warranty Parts. |
#4 (permalink) |
There is a special socket to hold the top of the shock bolt. If you have the bushings compressed and its good and tight, drive it around. If it's quiet, you should be ok. I've always just snugged them up with a 3/8" impact.
94 BBB Clone 94 9C1 LT1 93 GMC K3500 4x4 6.5TD 88 Chevrolet Suburban 6.2 3/4 Ton Ford Diesel Certified Technician |
| Sponsored links | |
| Springs question | cesars96 | 6th Gen Suspension | 7 | 01-02-2009 10:41 AM |
| modification question | swangn64 | Chevy Impala Discussion | 0 | 04-02-2008 06:32 PM |
| 95 vs 96 ss question | rhodymike | Chevy Impala SS Discussion | 2 | 02-05-2008 09:12 PM |
| 283 Question | DocP | 1st - 5th Gen Engine Performance | 1 | 10-17-2007 05:28 AM |
| Question about the Chevy S10? | Joe | General Automotive Discussion | 1 | 09-10-2007 04:15 AM |
