Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 6th Gen Discussion > 6th Gen Engine Performance
Old 04-29-2008, 07:10 AM   #1 (permalink)
happyhour's Avatar
vacuum line question for stock 1995
I recently made a mistake and had a shop replace the water pump and front seals. When I arrived home I found that they had not reconnected the electrical connection to the air pump. Once I fixed this I started to check all other work carefully. From the air pump up to the egr system there is a hose
(probably 1/2") that has what looks like a check valve with a very small port (maybe about 3/16" or smaller) for another hose or just an air vent. This fitting is just after a 90 degree bend exiting the air pump. There is no hose attached and I cannot find a loose hose. What concerns me is that the port is a very clean white color which indicates to me that something was covering it. I cannot find details in the online manual.
Can anyone tell me if this is just to be capped or is there a missing hose ?
happyhour is offline
Sponsored links
Old 04-29-2008, 01:45 PM   #2 (permalink)
oldskoolcaprice's Avatar
Post a pic with this to help us help you
1995 9C1 Caprice, 318,000 miles, 2" drop, wide whites, bilstiens, bmr front, rear, uppers & lowers, moog front-end rebuild, 2800 stall, 3.5 MAF, aftermarket dual 13" electric fans, and decent flat-black paint job!
oldskoolcaprice is offline
Old 04-29-2008, 01:51 PM   #3 (permalink)
For starters, you really don't need your air pump or smog pump (for states that check emissions refer the air pump as the smog pump), it was found by the EPA to do absouletly nada for the emission. You can actually remove this altogether, unless you live in Californication, where it needs to be on, but doesn't need to be running. So, if you live in a state that doesn't check emissions then take that sucker off.
Old 04-30-2008, 09:18 PM   #4 (permalink)
RoadMonster's Avatar
It's legal do disable but not to remove the air pump on 1995 & 1996 B Bodys.
There is a decal that GM made for this modification to the emissions system.
If you have smog checks, you might not pass the visual inspection if you remove the pump.
Stewart
Buick Club of America Member #43314
Buick Modified Division (BCOA) #109
1994 Buick Roadmaster Gran Sport
http://www.cardomain.com/ride/732699
1926 Buick Hot Rod
http://www.cardomain.com/ride/3185370
RoadMonster is offline
Old 04-30-2008, 09:20 PM   #5 (permalink)
moneypit
moneypit's Avatar
true...i am starting to hear some horror stories about crack downs at the smog shops due to recent fines....
Old 12-14-2008, 11:15 AM   #6 (permalink)
BYB_CUZ's Avatar
When i removed my air pump, i noticed it fixed alot of my idling and hesitation problems, I think i know what hose you are speaking off and mine broke off. Cause a major exhaust leak that i didnt discover for atleast 6 months. Post a picture of what you are speaking off.
BYB_CUZ is offline
Sponsored links
vB code is On
lincoln mark 8 stock (supercharged version) vs 94 impala ss stock in drag race? stvnbonilla Street Racing 5 04-26-2008 10:27 PM
My 68 Chevy Impala Came With An In Line 6? smrsancho Restoration Forum 1 08-31-2007 10:44 PM
eXTReMe Tracker
Sitemap Index - Archive
