is tuning required for a cc-306 cam? - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Chevy Impala 6th Gen Discussion > 6th Gen Engine Performance
Old 02-19-2012, 10:31 PM   #1 (permalink)
flynwgn95's Avatar
Send a message via AIM to flynwgn95
i am looking to put a cc306 cam in my wagon....is tuning required or can i just slap it and run it? anyone do this?
flynwgn95 is offline   Reply With Quote
Old 02-20-2012, 04:52 AM   #2 (permalink)
http://www.impalaforums.com/wagon-di...-the-boat.html
A STOCK cam benefits from tuning the stock cam is 191/195 the Comp 306 is 230/244.
The factory rev limit in first gear is 5500rpm(lower in higher gears), if your heads are decent the Comp 306 wont even peak till 6500. Now aside from the fuel and spark tables being all wrong for the cam change below the 5500rpm stock rev limit how well do you think a cam would work keeping it limited to 1000rpm below it's peak power?? Understand that to properly use a cam you need to rev several hundred rpm past peak power so you use the whole top of the power curve.
The valve sizes you listed in the other post suggest either you or your machinist don't have a clue, I do not believe the seats can be cut that big in GM heads and if they could be you wouldn't want to anyway, the fastest NA b-bodies are running 2.00/1.55 valves and the fastest 350 car is running less duration than you are proposing, my car runs less duration than this and it is one of the quickest truly street b-bodies.
Computer tuning would be needed just for the boltons to support the 306 cam, with a cam that big you would absolutely need high stall and in a wagon I would say 4.10 gears. Need a lot more other mods but those need reprogramming for.
This is all besides the fact the 306 is a dinosaur of a cam well known for it's tendency to surge even with reprogramming, this is marginally a better choice than the one you picked out last time but still way way out of line. If this is a street car I might aim for 32-3400stall 3.73s and something down around the Comp 503 as the max for a wagon.
If shopping Comp's catalog understand the rpm ranges listed are based on Gen1 stuff so they are several hundred rpms lower than a LT1 will need to turn, that Comp 503 cam I mentioned has a listed rpm range of 1800-5800rpm in practice guys with ported heads routinely turn it 6300-6500rpm.
Best guess as to why the rpm ranges are so bad is the LT1 intake's short runners favor high rpm.
A car needs a LOT of work before looking at a cam, being 16+yo cars fuel pumps should be upgraded, sometimes injectors upgrades are needed, need a good CAI and new exhaust from the manifolds back. Tranny rebuild is prudent, a stall and gears are absolutely necessary. Gears often make upgrading the driveshaft to an aftermarket one balanced to a higher rpm a good idea.
Then far as trying not to retune, things like larger injectors without reprogramming will actually destroy the engine, reprogramming is a critical part of performance modification.
Old 02-20-2012, 09:08 PM   #3 (permalink)
Gregg-O's Avatar
Flynwgn, You won't get a better answer than what Dwayne said. But I''l give you the short version answer to your question.......yes. LOL.
" The world ain’t all sunshine and rainbows. It’s a very mean and nasty place, and I don’t care how tough you are, it will beat you to your knees and keep you there permanently if you let it. You, me, or nobody is gonna hit as hard as life. But it ain’t about how hard you hit. It’s about how hard you can get hit and keep moving forward; how much you can take and keep moving forward. That’s how winning is done! "
Old 03-01-2012, 10:22 PM   #4 (permalink)
flynwgn95's Avatar
yea I am just looking for the right answers unfortunatly the A** that i was going to get the heads off of was going to do me wrong I found a good friend that set me up right but any way im only looking to go to 6500 max due to having 180,000 miles and im not doing the bottom end till i blow it.... sure the mileage is high but this car has been 100% maintained and for the past 4 years i have used nothing but mobile 1 on time every time it is still loaded with power and oil pressure is great so i assume i dont have much to worrie about....i say that loosly because i do expect to blow it when i take it to the track in April!! lol but any way let me know based on what i have and am doing i just posted another thread wondering if anybody has done something like me hopefully i hear something good otherwise i am going to record the run and youtube it
Required Smog Equipment List... Papa D Automotive Discussion 1 05-05-2011 10:12 AM
Chevrolet : Impala Base WE FINANCE NO CREDIT REQUIRED CLEAN CAR LOW MILES PMT!! RSS Bot eBay Cars For Sale: Impala 0 09-10-2010 12:10 AM
Corgi Chevrolet Impala TLC Required or good for bits!! RSS Bot Impala Diecast Toys Cars on eBay 0 09-03-2010 09:00 AM
How many spark plugs are required for my Chevrolet Impala 2003? pew pew man Autocare and Maintenance 44 01-28-2010 06:20 PM
1966 Chev Biscane R/R Fender Parts Required jat58 Private Wanted Classifieds 0 09-08-2008 07:37 AM
