Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 6th Gen Discussion > 6th Gen Engine Performance
Old 03-25-2008, 07:24 AM   #11 (permalink)
LeadSSled's Avatar
There is no one "best system". All of the performance exhaust systems of the same size will give similar improvements to your performance. So the decision as to what is right for you is what sounds pleasing to your ear. I run a 3" Clear Image system using SpinTech mufflers on mine. Here are a couple videos for a sound clip.
Here is one showing the car "at speed".
LeadSSled is offline
Sponsored links
Old 03-25-2008, 03:30 PM   #12 (permalink)
breetai's Avatar
Thumbs up
Originally Posted by clean94atl View Post
You can remove the cats even if u have an o2 lamda sensor, and not all states/counties have emissions testing, and also pipes 2 inches past the rear bumper, why? i have a flowmaster catback system minus the flowmasters mufflers, I just like the look of the long polished pipes, and the mandreal bends, Magnaflow has the best sounding and freest flowing mufflers, and there x pipes are hi quality. summit sells the o2 delete's, the catback flomaster system and magnaflow x pipe and magnaflow mufflers. Also u can get your ecm reprogramed to avoid the check engine light if u choose to go that route on removing your cats. just look at all the mustang off road x pipes, mustangs aren't exempt from emissions, and just about every mustang has cats removed.
Having the exhaust exit past the rear bumper puts the exhaust tips exiting into the forward swirl of the low pressure area behind the car, and actually makes the exhaust flow better by helping to "suck" the exhaust out of the tail pipe.
breetai is offline
Old 04-18-2008, 06:22 AM   #13 (permalink)
KW Baraka's Avatar
Originally Posted by weather View Post
what is the best performance exhaust system.......i dont want a really loud exhaust a nice sound(quiet sound) but more performance than anything.
From what you describe, I would say that Dynomax with either of their Ultra-Flo mufflers would be the best fit for ya.
I have this exhaust on both stroked my B-bodies .
Available at Summit Racing.
KW
1996 Impala SS and 1995 Caprice 9C1
KW Baraka is offline
Old 04-18-2008, 08:10 AM   #14 (permalink)
Roadhouse's Avatar
LeadSSled, that car sounds awsome!
1995 Impala DGGM SS
One of 4442 for 1995
Roadhouse is offline
Old 04-18-2008, 08:41 AM   #15 (permalink)
LeadSSled's Avatar
Thanks! It's been a labor of love - lots of blood, sweat, and tears (and cash ) in this project.
Old 07-31-2008, 04:55 PM   #16 (permalink)
Huff's Avatar
Send a message via Yahoo to Huff
i am running flowmaster 70's with no cats, and stainless tips.
Huff is offline
Old 08-01-2008, 11:39 PM   #17 (permalink)
maesstro's Avatar
HaHa! That four banger is ruining your autocross video about half way through! I know I've seen the first vid on the other forum, but I don't remember the second one. Thanks for posting, and as I'm sure you're aware, sounds great (your car, not the riceburner.)
maesstro is offline
Old 08-05-2008, 07:50 AM   #18 (permalink)
mr96ss's Avatar
i have the flowmaster 40 series. and i had it dumped out right after the muffler. and it gave me a low, nice deep rumble.... i like it
mr96ss is offline
Old 08-06-2008, 05:12 AM   #19 (permalink)
Gregg-O's Avatar
I'm really surprised at you running under the axle pipes, what do you do on a lift ? Hope you don't get airborn...lol.
X or H will improve your exhaust, ...like 'em or not.
$2000 for an exhaust system that doesn't even go over the axle....better be ceramic front to back or you got taken. OK headers could run almost a grand so.......
Gregg-O is offline
Old 08-06-2008, 02:57 PM   #20 (permalink)
RMC
RMC's Avatar
Originally Posted by TheFooserGuy View Post
Yes to Clear Image's ceramic-coated Tri-Y's with their 570 CFM cats and all four O2 sensors (http://www.clearimageautomotive.com/...haust/TriY.htm) WARNING: THIS IS NOT A CHEAP OPTION!
Yes to MANDREL BENT (NOT "compression bent") piping (2 1/2" will handle things up to abut 500 HP). I went straight out UNDER the rear axle (right under the upward 'kinks' in the rear swaybar - if you hit a bump the axle goes UP - not down, think about it) ... but then I like the cackle of (2) 5-foot straight pipes.
(Screw X-pipes, H-pipes, cross-overs, etc. I can take down one side or the other without needing a rack or an army of friends to help lift things.)
My exhaust: (headers, cats, mufflers, custom bent pipes and polished stainless tips - all custom installed)... +/-$2000
- worth every dime.
TheFooserGuy... Sorry, but Gregg-O is right about the X-/H-pipe, especially for street machines. It will increase low-/mid-range torque with no penalty on the top end [based on testing that I have seen]. It also quiets the exhaust down a little [good or bad, depending on your perspective]. Use band clamps on either end for ease of removal for trans servicing.
Gregg-O... I think a huge chunk of that $2000 is those cats. Dan of Clear Image was talking about them last year on the other forum and they are quite unique. They have some type of coated metal spirals(?) instead of the regular brick (or much older pellets). They are supposed to be super low-restriction. Also, ceramic coating on Tri-Y's [which are almost full long tube headers] cannot be cheap either.
RMC is offline
Sponsored links
vB code is On
performance chips a_zbhai 7th Gen Engine Performance 3 04-09-2008 09:42 PM
Performance Chips ImpalaRacer 7th Gen Engine Performance 2 11-20-2007 11:39 AM
Any FWD LS4 performance websites out there? The King General Automotive Discussion 0 09-13-2007 12:50 AM
eXTReMe Tracker
Sitemap Index - Archive
