Hope all is well with everyone!
I recently noticed my tempreture was redlining. I checked under the car and hood to see if there was any fluids or breaks in the hoses, and there was nothing. I then noticed that only fan#2 on the passenger side would come on after the temp was hella high then the temp would lower. I also noticed fan#1 never came on at all.
I figured the relay, fuse or motor was out. I checked them all and they turned out ok. I removed fan#1 and conected it to fan#2's conector and the fan#1 worked. I replaced the relay and fan#1 still didnt come on.
My boy did a little wazzu thing where he took some wire and by passed the relay at the fuse box and fan#1 ran and stayed on even with the ignition turned to axilary. We used a test light at the electrical conector, the relay terminal and it checked out good, however fan#1 will not come on.
I looked in the Haynes manuel and it said something about the coolant temp sensor posibly being a factor after runing these test, but I cant see how. Does anyone know what could be the problem and if there was a short circut, why would fan#1 come on after my friend bypassed the relay?
