secondary air pump? - Chevy Impala Forums
post #1 of (permalink) Old 04-29-2010, 12:40 PM Thread Starter
impala_prince's Avatar
secondary air pump?
My engine light came on recently and when I had my fellow club memeber/ mechanic check it out, after everything was said and done..it was the secondary air pump... it was gonna cost like 350.00 which I didn't have @ the moment... so he told me it serve any purpose at all (which I have a hard time to believe)... I need some input becouse my engine light would come on and go off just becouse of that secondary air pump....I aslo found that a lot of members of the inc clubs just take them off.
impala_prince is offline
post #2 of (permalink) Old 04-29-2010, 12:46 PM
COLD STEEL's Avatar
The pump can be disconnected and disabled. GM has a program that we use to update the computer to delete the air pump from programming. This way its not in the system and you do not have to physically remove it. There is also a Federal emissions sticker that needs to be placed where visible to avoid any problems in emissions states.
Right now you can unplug the pump or remove the fuse for it.
COLD STEEL is offline
post #3 of (permalink) Old 04-29-2010, 12:52 PM Thread Starter
So basically it serves no purpose...
post #4 of (permalink) Old 04-29-2010, 12:56 PM
COLD STEEL's Avatar
By now the only purpose it serves is dead weight. When it was new it used to be part of the air injection system. Most at this age no longer function and are usually full of rocks/gravel and dirt.
post #5 of (permalink) Old 05-23-2010, 03:28 PM
SuperSport's Avatar
Took mine off.... working on the EGR delete as well. Dead weight is right! Remove the piping & buy a couple of plugs. On my way to NAPA to get mine.
'95 Impala SS --- Low Budget Mods... More to come!
SuperSport is offline
post #6 of (permalink) Old 04-02-2011, 08:34 PM
franciscocampos's Avatar
Question
What size plugs did you use for the air pump delete as well as the pulley for the air pump? I don't have a need for it being that I am about to put long tube headers on my 95 Impala with no catalytic converter. Thanks for the help regarding this matter. Also what did you do for the ERG delete?
franciscocampos is offline
post #7 of (permalink) Old 04-02-2011, 11:38 PM
MrBuick (Magnum)'s Avatar
The 94-96 Air pump is electronic, meaning, no pulley. Mid way through 95, they switched to a different style air pump fitting at the exhaust manifold. The manifold threads are different as well. We would need to know which style fitting the 95 has, first.
For the EGR delete on 94/95's, you just put a plate on the intake, and the exhaust manifold. Stops working, and no CEL.
MrBuick (Magnum) is offline
post #8 of (permalink) Old 02-01-2015, 09:57 AM
gary821's Avatar
having trouble with water that got into my secondary air pump. motor is on bottom of mount. going to turn pump so it is on top so water won't run into it. not sreal sure if it will work but it's worth a shot. also put in a couple of 1/16 drain holes in blower case for drainage. waiting on new pump motor. let ya know what happens
gary821 is offline
post #9 of (permalink) Old 02-01-2015, 03:12 PM
Quoted: 18 Post(s)
Are you aware there is a TSB defeating the AIR pump by GM for the 95-96 cars?
Dwayne J is offline
post #10 of (permalink) Old 02-02-2015, 12:18 PM
gary821's Avatar
Read something about it. this problem is on my 2000 impala ls. chevy dealer wants 80 bucks to take it out of system. pump cost me 84 bucks. guess it just depends on which way you want to go. cost is pretty close for me so i'm going to attempt to fix it. I
hope
gary821 is offline
post #11 of (permalink) Old 02-02-2015, 07:04 PM
Quoted: 18 Post(s)
I presumed you had a 6th gen.
Dwayne J is offline
post #12 of (permalink) Old 02-05-2015, 04:35 PM
gary821's Avatar
I think it's a 6th generation . It's a 2000 impala with 3800 engine. I redesigned on how they had air pump put in. I made it so the motor is on top and the pump is on bottom. Figured that way water wouldn't have a chance of running down in it. Had to do some cutting on hoses to make it work but wasn't that bad. hoping this works out
gary821 is offline
post #13 of (permalink) Old 02-05-2015, 06:32 PM
Quoted: 18 Post(s)
That is 7th gen.
6th gen was the RWD of the 90s.
Dwayne J is offline
post #14 of (permalink) Old 02-28-2015, 08:42 AM
gary821's Avatar
Originally Posted by Dwayne J View Post
That is 7th gen.
Got a new secondary air pump and turned it so motor is on top and not on bottom to avoid any water getting in it. Also replaced check valve and I'm still having the 30 amp fuse blow out on me.???????. Only thing I could think of is that we here in Ohio have been having really cold weather and that water in line might of froze blocking it and causing a strain on the air pump. Any ideas of what might be wrong? Also got the same code fault as before, p0410.
gary821 is offline
post #15 of (permalink) Old 03-07-2015, 11:27 AM
gary821's Avatar
Is there a GM app to remove the secondary air pump from the computer on a 2000 impala ?
gary821 is offline
Air pump podeveryday Chevy Impala 6th Gen Discussion 14 03-05-2010 09:55 PM
Secondary air pump and check valve on a 3800 - where??? Gator762 Chevy Impala 7th Gen Discussion 1 07-14-2009 07:50 PM
Secondary fan wont turn on?????? rocky$$82 Mechanical and Electrical Problems 10 05-27-2009 09:20 AM
Air Pump JamesM Automotive Discussion 2 11-22-2008 07:57 PM
2003 Impala 3.8 - Secondary fan/overheating mrdillen Chevy Impala Discussion 0 07-26-2008 10:06 AM
