An Afternoon of Upgrades/Caprice 9C1 - Chevy Impala Forums
post #1 of (permalink) Old 12-10-2009, 06:52 AM Thread Starter
Pablo Chang's Avatar
Hey , few quick questions: I have a 94 Caprice LT1 and was going to do some upgrades.
1) any advice/comments on a performance chip? Was thinking of going with the JetChip 2
2) I’ve seen it recommended to switch to a lower temp thermostat like a 180degree,
Ive also seen 160 degree ones, any drawbacks/concerns going with the 160?
3) how hard is it to swap TBIs in the LT1? What size is stock and what might be a good size to swap to? (Car is basically stock now with 2.25 mandrel bent exhaust, stock cats,resonators deleted and mufflers real similar to flowmasters and will be adding the K n N cold air setup at the same time)
4) Is it worth finding a high flow/low res MFI sensor for the car? Ive seen it where people have put ones from z28s or corvettes whatever. Is it a simple put in,click the connectors and it works? Would there be a noticeable improvement?
5) Is it worth re-routing the coolant away from the Throttle Body? Is it an easy thing to do?
AND would it be ok to do all/most of these mods at the same time or is there a particular order I should follow? The reason I ask is I have no garage and was thinking about getting a an acquaintance to lend me his workplace/tools and maybe a helping hand as I’m not very mechanically inclined (I’m trying tho)
Sorry about the long post,I’m just overly excited with my new car and with this site!
Ive learned a lot so far,you guys have been great!
Pablo Chang is offline
post #2 of (permalink) Old 12-10-2009, 07:52 AM
w the 160 thermo if u have cold winters your heat wont be as hot as u like , id remove hoeplate and maybe first base while your in there
i dont know 1 person on here that would mess with the CHIP
also our cars are not tbi there fuel injected
hope this kinda helps
ask away w more questions or ust look at people olds post for the cold air intake and homeplate/ first base delete
4 B BODIES
2 SOLD CAPRICES
post #3 of (permalink) Old 12-10-2009, 08:31 AM Thread Starter
Oh, I gotcha, I meant the 'throttle body' not the 'TBI'
thanks
post #4 of (permalink) Old 12-10-2009, 08:34 AM
thanks
to get say a bbk aftermarket t.b u have to do alot of OTHER upgrades to get the full potential that it has maybe cam work, springs ,roller rockers so for the money its not a good first upgrade , jsut put the money towards something else until u really need it
4 B BODIES
2 SOLD CAPRICES
post #5 of (permalink) Old 12-10-2009, 08:39 AM
COLD STEEL's Avatar
Quit horsing around with so called "chips." The best bang for your buck will be to have a computer tune. Many out there who handle that (pcm4less,trifecta,etc...) start there if you already have intake/exhaust handled. If you did your exhaust and did NOT install a true X pipe, not the kind they make you while your there, then you are missing out on a lot of mid range hp.
COLD STEEL is offline
post #6 of (permalink) Old 12-16-2009, 05:48 AM Thread Starter
mods
OK thanks guys.....I will go for the pcm tune rather than a 'chip'
I wasnt quite sure what it was but Ive since researched and it makes sense.
I will also hold off on upgrading the TBU till I do headwork,cam,headers and such.
Should I hold off on getting a higher flow/lo-res MAF sensor or is that ok to do
as one of the first mods?
I can deal with 'not so hot heat' and will go with a 160degree t-stat
(unless theres a reason I shouldnt?)
Will rerouting the coolant around the tbu be a good first kinda mod?
will these 2 coolant type mods make any kind of noticable difference
in performance?
thanks in advance for all your help!
Pablo
post #7 of (permalink) Old 12-16-2009, 08:25 AM
routing the tb coolant is a well known mod i ahvent done it i dont really care
u can buy a 3.5 maf form an f body trans am i believe and its plug and play
4 B BODIES
2 SOLD CAPRICES
post #8 of (permalink) Old 12-17-2009, 05:33 PM
HERD546's Avatar
Mods for a 9C1.
Have a look at the S&B filters web site they make a reasonable cold air intake for our cars.
Check with Mike at Focuztech he usually has them in stock, He is a sponsor of this forum. I got one when they were on sale and got a great deal.
Take off the first base and use a hockey puck from your favorite hockey team to fill the hole where first base was.
Check around your area for an Impala Club or F-body club they most likely have a computer tuner.
We have Ion http://www.madz28.com/ Ion has a mail order program.
PAUL R DUMDIE JR.
HERD546 ISSCA 2158
W9DWP AZISSO 460
www.theherd.com
1996 DGGM IMPALA SS
1995 BLACK Carprice SS WAGON SOLD..
1992 Dk Gray Caprice SS WAGON SOLD..
2008 Impala LT
2002 Impala LS
2009 White TAHOE Z56 PPV..
HERD Club Vice President & Events Coordinator.
HERD546 is offline
LinkBack to this Thread: http://www.impalaforums.com/6th-gen-engine-performance/241633-an-afternoon-of-upgrades-caprice-9c1.html
N N Caprice Ss Mods - Resources This thread Refback 03-29-2011 08:16 AM
upgrades 00 impala Automotive Discussion 4 08-24-2009 09:55 AM
07 impala ls upgrades wyotechimpala Chevy Impala 8th Gen Discussion 3 02-23-2009 10:40 AM
upgrades? bigred1 Chevy Impala 7th Gen Discussion 8 02-07-2009 04:17 PM
New Upgrades? DrewBoi 7th Gen Engine Performance 22 01-21-2009 06:15 PM
upgrades on a 1993 chevy caprice 5.7 police interceptor? Robbie Chevy Caprice 2 07-11-2008 08:21 PM
