Chevy Impala SS Forums
Go Back   Chevy Impala SS Forums > Performance and Technical > Chevy Impala 6th Gen Discussion > 6th Gen Engine Performance
Old 02-16-2009, 09:47 AM   #1 (permalink)
podeveryday's Avatar
A few raiss questions
Remove this ad!
Has anyone had issues with driving in rain or bad weather? Also what have you guys done with your air pumps? I dont have headers yet so i was going to wait till i got them to remove it since you need a tune to shut off the air pump. Does anyone know what size breather i need to attach directly to the air pump? Thanks.
podeveryday is offline
Old 02-16-2009, 10:10 AM   #2 (permalink)
George Bates Automotive's Avatar
I had it (won it at silent auction at the first West Coast Gathering in Vegas) and it worked well. In very windy,dusty areas it does collect debri but it easily wiped out/off. I drilled 2 very small holes in areas at the lower corners just in case and moisture built up which it never did. It is important to clean the M.A.F sensor every couple weeks.
As for the air pump, I did a factory update to delete it legally and added the Legal delete/update factory sticker to the radiator support shroud so the emissions guys can see it. That took away any need to have a breather for the air pump since the air pump was no longer bolted on.
My name is Angel. I have been around B-bodies since mid 2000 and have been working on them since about 2002. I work at a shop that specializes in the repair and restoration/refurbishing of 91-96 Caprice and Impala cars. I do not and have not claimed to know everything about these cars, but by seeing a great deal of these cars daily I can usually be of some help in giving advise when a problem comes up. Feel free to ask questions
George Bates Automotive is offline
Old 02-16-2009, 10:50 AM   #3 (permalink)
Erik's Avatar
As far as the filter for the air pump, just pull the hose and measure the inner diameter. I don't know the size, but the K&N cold air intake does come with a smaller filter for the air pump that slips inside the hose. On the K&N, there's a small hole in the cold air box for the filter. I don't know if you'd want to drill a hole in the RAISS though.
Nodding Tiger Mod
Erik is offline
Old 02-16-2009, 03:15 PM   #4 (permalink)
So do i put the breather right on the end of the air pump or on the end of the hose? Also can i start the car just to see what it sounds like now with the air pump hose just hangin there with no breather?
Old 02-16-2009, 03:18 PM   #5 (permalink)
Erik's Avatar
Without having looked at an air pump in a bunch of years, I'm going to go ahead and guess that you'd pretty much HAVE to put it in the hose. Otherwise, where's it going to go? In other words, use the hose as a coupler and make it whatever length you want to put that little filter someplace that makes sense.
Nodding Tiger Mod
Erik is offline
Old 02-16-2009, 05:12 PM   #6 (permalink)
Thanks for the tips fellas, Yes an outerwear is a must i ran them on my atvs and they make a huge difference especially in the dirt, as far as cleaning the maf every few weeks hopefully the pre filter lower that to every few months. How do u clean the maf? Thanks again, Ill call around for the breather tomorrow, now its on to the exhaust, proper rear end gasket, and checking out the ball joint tourqe since im having some front end noises and play.
Old 02-16-2009, 05:15 PM   #7 (permalink)
CRC makes a MAF aerosol cleaner, just spray it on the MAF elements and connections and your good to go.
Old 02-16-2009, 10:50 PM   #8 (permalink)
Gregg-O's Avatar
I'm going to take a guess that the MAF cleaner is NOT the same stuff as throttle body cleaner...?
Gregg-O is offline
Old 02-17-2009, 08:20 AM   #9 (permalink)
Correct, the TB cleaner is very harsh and cannot be trusted to be used on the MAF, however, the MAF cleaner can work for both.
Old 05-17-2009, 04:54 PM   #10 (permalink)
94loveboat's Avatar
what is this air pump and stuff your talking about, wut does it do, im still learning about my car, is this hose ur talking about fit to teh factory air box?
94loveboat is offline
Old 05-17-2009, 06:06 PM   #11 (permalink)
94loveboat's Avatar
what the heck is the point of putting air in the manifolds and why someone designed it???
Old 05-18-2009, 03:23 PM   #12 (permalink)
94loveboat's Avatar
i just got done putting in my intake, and the air pump hose i just ended up sticking it in my intake tube that came with my kit becuz it actually had a hole already drilled out so thats where it went, check it out at my cardomain page at 94roadyLT1, all for 80 bux
Old 05-18-2009, 03:36 PM   #13 (permalink)
Originally Posted by RoadMonster View Post
The air pump is located on the drivers side lower
front of the engine. It pumps air into the exhaust
manifolds at start up. See those metal tubes running
into the top of the exhaust manifolds? That's for
the air pump.
It has a hose that runs into the factory air intake to get
clean filtered air from.
When you delete the factory intake garbage, you need
to cut the hose on the air box shorter, and install a little
K&N style filter, or better yet, delete the whole thing altogether.
This is, of course, if you don't live in California, or someplace
where you will need to pass a smog inspection, particularly
a visual inspection.
In California, We can help with that problem
Old 05-19-2009, 03:28 PM   #14 (permalink)
BBSmoov's Avatar
I was looking into those on Ebay
I was looking into those on Ebay. Does it move around when you drive or is it on pretty tight? Are you going to make some kind of heat sheild? I heard that aluminum attracts heat and you get more cold air with plastic. Have you noticed a difference, besides the sound? Nice job btw and sorry for so many questions.
BBSmoov is offline
Old 07-26-2009, 10:12 PM   #15 (permalink)
samtheman209's Avatar
ouenonewonfewo
samtheman209 is offline
Box Questions jdawg Audio, Video, and Electronics 7 06-03-2009 12:55 PM
Got an 08 SS. Few questions ISHAMS00VETTE Chevy Impala 8th Gen Discussion 10 03-09-2009 05:55 PM
more questions Bizkitss81 Chevy Caprice 10 02-11-2009 07:00 PM
2 questions k3n12ock Audio, Video, and Electronics 1 11-29-2008 08:02 PM
RAISS Cold air Intakes Ons Sale- MikeT Automotive Discussion 2 09-17-2008 06:26 AM
