An exhaust leak at the exhaust manifold(s) could cause the noise and
the performance issue. It is very common for these cars to have exhaust leaks from the exhaust manifolds. The bolts break or back out. My car had a ticking sound when it was cold, but the sound would go away when the engine warmed up. When I switched to headers, I found that both rear bolts on both sides were broken off. Lucky for me, the headers I bought don't require the use of those bolts. For whatever reason, GM did not use good quality exhaust manifold bolts on these cars. I'd start by doing an inspection of your exhaust system. If you find that you do have an exhaust leak, there are grade 8 bolt kits available for your stock manifolds. If any bolts are broken off, you might get lucky and use an EZ Out to remove it. If you can't get a broken bolt out, an exhaust shop should be able to help you out. You may even be luckier, and maybe the bolt fell out ![]() Hope this helps. Stewart
Buick Club of America Member #43314 Buick Modified Division (BCOA) #109 1994 Buick Roadmaster Gran Sport http://www.cardomain.com/ride/732699 1926 Buick Hot Rod http://www.cardomain.com/ride/3185370 |
#3 (permalink) |
I agree that it is most likely an exhaust leak. I had the infamous "ticking sound" before, and it turned out to be a leaking header gasket. I pulled the headers (a serious PAIN with the Hookers), replaced the gaskets and reinstalled. Shazaam! No more ticking noise!
#4 (permalink) | |
| Sponsored links | |
| How Can I Make My Impala Sound Like An 350Z or G35 etc ..? | gunpoint_tx | 7th Gen Engine Performance | 4 | 01-05-2009 03:40 PM |
| sound system in a 2001 impala? | Heather Z | Chevy Impala Discussion | 2 | 11-13-2007 05:43 AM |
| 2001 impala when i start my car is makes some type of sound and and the engine | envy_delros | Mechanical and Electrical Problems | 1 | 09-20-2007 10:52 PM |
| what would make a 2000 gmc Sierra 5.3L V8 sound beefier? | Austin | General Automotive Discussion | 0 | 09-16-2007 11:54 PM |
| I am having problems with my 2005 GMC Z-71!!! There is a horn sound that | Monkey | General Automotive Discussion | 0 | 09-13-2007 02:41 PM |
