Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Chevy Impala 6th Gen Discussion > 6th Gen Engine Performance
Old 08-12-2008, 09:07 PM   #1 (permalink)
impaladreamer_30's Avatar
Ram Air Intake
ok
i've been doing alot of research on which RAM AIR hood is the best
and i have come to the conclusion that the suncoast ram air hood is #1.
because of several factors, the biggest one being that there are 3 intake systems already built for it and the fact that it is the only hood i found that has a 3 year warranty!!!!!
now, which intake system is better the RAISS, the suncoast ram air kit, the super stealth? and what makes it better than the other one?
thanks alot for your help
impaladreamer_30 is online now
Sponsored links
Old 08-13-2008, 03:10 AM   #2 (permalink)
Gregg-O's Avatar
Gee, This is a hard one........How about the Suncoast hood with the matching intake kit that makes the whole system work as designed.
Gregg-O is offline
Old 08-14-2008, 01:41 PM   #3 (permalink)
Just got done e-mailing a tech at suncoast
this is what he had to say:
"Both systems will give a boost in performance and work well with the Suncoast Ram Air Hood. Your decision should be based on whether you want maximum power or a balance of power and showmanship. As I said before both the RAISS and the Suncoast systems will add power. The key difference between them is the Suncoast system is designed to give maximum power and sacrifices "glamour" while the RAISS system gives a good power add in a showy package...."
Thought I should share this info so nobody has to deal w/ the headaches of deciding which one to get ….
THANKS GREGG-O …. for your input
Old 08-14-2008, 01:51 PM   #4 (permalink)
EU4IC's Avatar
Send a message via AIM to EU4IC
I have heard however that Suncoast takes a good while to ship out a hood while the other places are a little faster.
SS My Anti Drug
EU4IC is offline
Old 08-14-2008, 08:48 PM   #5 (permalink)
I'd rather deal with Suncoast directly because they actually manufacture these hoods .... plus they make sure the intake system you buy fits perfect (at least, that's what they told me)
it better fit perfectly after spending over $1200 .......
I've been doing alot of research on lots of hoods. Almost 6 months of back and forth e-mails with different manufacturers of custom hoods ..... fiberglass hoods, carbon fiber hoods, ..... i'm glad it's over though
i'll wait an extra week or two to be sure everything goes smoothly ....
thanx for the heads up though
Old 11-18-2008, 09:57 PM   #6 (permalink)
Supporting Vendor
Clear Image Auto (Dan)'s Avatar
Years ago there was an intake comparison done. (This was before the RAISS). The SSRI, K&N, RAMMIT and SSRI with Suncoast hood were all tested. The SSRI flowed more than the others but was beat by the SSRI/Suncoast hood combo. We carry the Suncoast hood, the SSRI and the RAISS and in my opinion, the best combo is the Suncoast hood with SSRI. Simply because the SSRI allows the benefit of the air coming through the front grill and the hood scoops while allowing the air to head straight into the engine, just like the RAISS. The Suncoast box is not a straight shot into the throttle body and uses a more restrictive air filter than the SSRI or RAISS use. Also, the SSRI uses a larger filter than the RAISS allowing for more flow.
Warmest regards,
Dan Ferraro
Headers, Exhaust & Intake systems
dan.ferraro@clearimageautomotive.com
Clear Image Automotive
www.clearimageautomotive.com
Clear Image Auto (Dan) is offline
Old 11-19-2008, 04:52 PM   #7 (permalink)
White93ltz's Avatar
I was going to post the exact same thing as Dan and then I saw his post.
The Suncoast intake is not that great. The RAISS or SSRI are much better even when used with the suncoast hood. I believe a recent redesign in the hood has gotton rid of the old problem where the hood didnt meet the intake.
I will give a big plus one to the Suncoast hood being the best.
Mine is 10+years old and fits very well considering I never had it professionally installed, and just slapped it on in 20 minutes.
I've seen the new version of the hood, professionally installed and painted, and it's absolutely flawless. Looks just as if it rolled off the factory line that way.
White93ltz is offline
Old 11-19-2008, 08:07 PM   #8 (permalink)
RoadMonster's Avatar
I like the RAISS best.
Just my .02
Stewart
Buick Club of America Member #43314
Buick Modified Division (BCOA) #109
1994 Buick Roadmaster Gran Sport
http://www.cardomain.com/ride/732699
1926 Buick Hot Rod
http://www.cardomain.com/ride/3185370
RoadMonster is offline
Old 11-19-2008, 08:36 PM   #9 (permalink)
Just my .02
Stewart
LOOKS AWESOME ..... getting mine soon (need $$$ though)
Old 12-15-2008, 08:01 PM   #10 (permalink)
podeveryday's Avatar
Does the raiss with the twin intake come with the prechargers for the filters?
podeveryday is offline
Sponsored links
vB code is On
Air Intake Upgrade impaladreamer_30 Chevy Impala 6th Gen Discussion 2 08-18-2008 07:16 PM
intake kits Teds06Imp69 8th Gen Engine Performance 0 07-02-2008 11:02 AM
is there anyone who can tell me what this intake manifold came off of? Bigidy_B General Automotive Discussion 1 09-07-2007 07:22 AM
short ram intake vs stock intake? clay10_91 General Automotive Discussion 2 09-06-2007 03:04 AM
eXTReMe Tracker
Sitemap Index - Archive
