| 6th Gen Drivetrain Transmissions, clutches, and axles. |
Idling problems.
Ok so hoping to get somewhere here with this. I have a 96 Impala and when sometimes idling my rpms shoot up like crazy then go back down. It'll start at 1,000 and then shoot up to 1,500 then drop back down to about 900 or 800 rpm and would continue to do so. And this problem also sometimes occurs when at a red light. Rpms will rise and I have to step on the brake fully down so I won't hit the car In front of me. Any help with this problem? Thanks for any suggestions!
| Sponsored Links | |||
Advertisement | |||
1996 CHEVROLET IMPALA Idle Air Control (IAC) Valve
Idle Air Control (IAC) or it is carbon around up around the iac valve and seat area.. You could try a good soak of carb cleaner, deep creep from sea foam or straight sea foam may be the first starting point before you get into replaceing the ica. If you do have ti iac valve unpluged or removed there is a relearn program to get it to run right. __________________ Welcome to the forum |
#4 (permalink) | |
![]() __________________ '95 Impala SS --- Low Budget Mods... More to come! ![]()
#5 (permalink) | |
I ask cause I have never worked on these cars. This is my first car and I am the third owner that is changing everything on it. All parts on this 96 Impala were all stock bone from when it rolled off the line in 1996. Until it got in my hands when i started replacing parts. So any advice on replacing it would help. |
#6 (permalink) | |
Good luck! ![]() __________________ '95 Impala SS --- Low Budget Mods... More to come! ![]()
#7 (permalink) |
The Unscrupulous Lt. Colonel
![]() ![]() Join Date: Mar 2011
One other thing that comes to mind would be the Throttle Position Sensor. A faulty one will cause idling problems and throw the transmission off because it wouldn't know when to shift. Also located on the throttle body and is the second sensor directly on top of the IAC sensor.
__________________ 2001 Chevy Impala 3.4 - Traded 2004 Chevy Impala 3.4 - Traded 2002 Chevy Impala 3.4 - RIP 1.12.2011/ Ice Storm 1996 Chevy Impala SS - RIP 4.15.2012/ Asswipe 1996 Chevy Impala SS - Current |
#8 (permalink) |
Thanks for both of you alls advice. I would ask my older brother..but he's just a plain d**k when it comes to me asking stuff about this. Will try and see if possible fix that this weekend wig my old man. Since I will be messing around the TB wouldn't it be ok to clean that too with some carb cleaner??
| Sponsored Links | |
Advertisement | |
| '95 Caprice LT1 idling rough after plug change? | Erik the Red | Chevy Impala 6th Gen Discussion | 3 | 06-01-2012 05:21 AM |
| 84 Caprice 305/700R4 idling rough | HAFROD | Mechanical and Electrical Problems | 2 | 02-04-2012 09:28 PM |
| no heat when idling | scrapdaddy | Automotive Discussion | 12 | 04-25-2010 05:22 PM |
| 2000 Chevy Impala; stalls when idling.? | Dr. Deviance | Chevy Impala Discussion | 4 | 04-14-2008 04:24 PM |
| Does anyone know anything about idling problems with an 01' Pontiac Grand Am? | XiE18 | Automotive Discussion | 8 | 09-04-2007 05:41 PM |
