77 impala rear disc brake conversion kit? - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Impala 1st - 5th Gen Discussion > 1st - 5th Gen Suspension
1st - 5th Gen Suspension Springs, shocks, and brakes.
Old 09-20-2007, 05:08 PM   #1 (permalink)
ufuknut
ufuknut's Avatar
does anyone know where i can buy a conversion kit for a 77 impala. i need to replace the rear drums to disc.... thanks
yea i thought about all the other parts that i need to change... money at this point is not an option, this car is already beign rebuilt from the frame and up. im already changing everything. its going to be a show car so the newer things i put the better.
Old 10-20-2007, 09:46 PM   #2 (permalink)
77bbod's Avatar
Contact Kore3, they should hook you up using C5 brakes. Post some pics of that bad boy you got!
77bbod is offline   Reply With Quote
Old 03-30-2008, 10:54 PM   #3 (permalink)
turboking84's Avatar
call up summit racing or jegs
Raymond Santos III
turboking84 is offline   Reply With Quote
Old 06-02-2008, 11:18 AM   #4 (permalink)
bnelsonva's Avatar
rear discs
Go to www.classicindustries.com and search for part # A1254. I can't vouch for it; I just saw it in a catalog.
bnelsonva is offline   Reply With Quote
Old 08-13-2010, 07:46 PM   #5 (permalink)
Osborn F. Enready's Avatar
Thanks for the Kore3 name. Haven't heard of them and they have some nice hardware.
Osborn F. Enready is offline   Reply With Quote
Old 08-13-2010, 07:53 PM   #6 (permalink)
Might consider an axle from a 94-96 Impala or 9C1 as those got discs, and being a factory setup parts are easy and relatively cheap. Also gives you a nice strong 30-spline 8.5" strong as a 12-bolt.
Not sure if the brakes from those would retrofit to your axle or not.
64 Impala disc brake conversion kit bnelsonva 1st - 5th Gen Suspension 9 03-10-2013 04:12 PM
disc brake and 14" rims rgfroom Restoration Forum 2 03-17-2009 12:29 PM
What's involved in changing rear disc brake pads on a 2006 Impala? moses2112 Chevy Impala Discussion 1 08-16-2008 11:01 PM
Chevy Caprice rear window conversion kits? The R Chevy Caprice 1 08-14-2008 09:26 PM
im looking to do a dics brake set up on a d60 rear diff? raelayotte Automotive Discussion 1 09-07-2007 04:16 AM
