legitimate suggestions? performance increases? - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Impala 1st - 5th Gen Discussion > 1st - 5th Gen Engine Performance
Old 07-15-2012, 04:54 PM   #1 (permalink)
velvet muldoon's Avatar
I've had my car since high school(im 27). It's a 1970 Impala with a small block 400 that has been rebuilt and fitted with an Edelbrock intake, carb(1406), and cam(2103). Headers, dual exhaust, and an old HEi that does now have 12 volts going to it.The original TH400 is in it and has been rebuilt. I guess my question is for the experienced drive train builder. I know little about heads and rear end gears. Heads are stock and so is the rear end.any cheap upgrade ideas? also does anyone have any idea what hp i may be getting currently?comments about a similar application welcome as well. Thanks in advance.
velvet muldoon is offline   Reply With Quote
Old 07-15-2012, 08:32 PM   #2 (permalink)
Gregg-O's Avatar
Hard to say, alot depnds on what was done during the rebuild. What comp. ratio you are running etc, etc, ... top HP for a stock '70 400 was 265...at the flywheel. You are probably a little over 300. Again, depending on the rebuild, and since I assume it's running, than the heads would probably like some new springs & some roller rockers, maybe go up to 1.6. rearends are not cheap...period, but a gear change & a good T. convertor in that TH400 would wake it up a bit. A 700R4 would be a better yet upgrade.
If you have fear of some pain or suffering, you should examine whether there is anything you can do about it. If you can, there is no need to worry about it; if you cannot do anything, then there is also no need to worry.
Old 07-16-2012, 10:03 AM   #3 (permalink)
Back in Black
12ltz's Avatar
I would also dump the HEI for a solid state unit. Some reuse the stock housing
12ltz is offline   Reply With Quote
Old 07-16-2012, 11:17 AM   #4 (permalink)
Wtf? Why would you change out the HEI? As shaft driven distributors go, you can't really do any better.
Old 07-16-2012, 01:38 PM   #5 (permalink)
nicke's Avatar
Agreed.
Find out what your axle ratio is (stamped on passenger side axle tube facing front of car) and let us know. I just switched my 3.07 gears for a set of 3.73 gears and swapped out my powerglide for a 200-4r in my 65 SS.
Dollar for dollar, a rear end swap can be hard to beat if you are in the 2's right now. If you do much highway driving, an OD tranny would also be a good call.
As far as heads go, a nice set of vortecs (with correct manifold) can add almost 40hp off the bat with your current setup, and not too expensive. This also might be a good option for you.
-Nick
nicke is offline   Reply With Quote
Old 07-16-2012, 08:30 PM   #6 (permalink)
no i just meant that when i replaced the original distributor with an hei i changed the main power to 12v as opposed to the resistance lower voltage wire that comes stock with the original. is this not a good thing? is HEI not preferable to the original? and i could not find the ring gear stampings where you suggested. ill look again though.
Old 07-16-2012, 08:38 PM   #7 (permalink)
Gregg-O's Avatar
-Nick
I don't think you can bolt Vortec's on to a 400 without drilling some some steam holes in them. IIRC that was a big issue BITD when guy's would throw a set of heads on a 400 from another SB engine, they would crack.
Old 07-17-2012, 08:29 AM   #8 (permalink)
Back in Black
12ltz's Avatar
Change it out to one with external coil, more spark.
Yes as stock units go the HEI was one of the better one.
Sorry for the confusion.
Old 07-17-2012, 11:20 AM   #9 (permalink)
nicke's Avatar
Yea, you are correct. Any heads besides the 400 heads will need the steam hole provisions drilled, which is why 400's get a bad rap for overheating.
Almost every good machine shop can make these adjustments to the heads.
-Nick
Old 07-17-2012, 04:11 PM   #10 (permalink)
You will not need more spark than an HEI provides, leave it alone, anything else is wasting money.
Old 07-17-2012, 08:29 PM   #11 (permalink)
Gregg-O's Avatar
I put one of these on my last 1st gen 355 that was pushing about 375 HP, made a big difference all around, but above 5500rpm & starting was alot better than stock.
http://www.summitracing.com/parts/SUM-850030/
Old 07-17-2012, 08:58 PM   #12 (permalink)
rock on i get it. but back to the rear end, mine is a completely stock 4 door's rear end. should i leave it alone? or is there more fun i could be having? within reason, im blue collar, and this is my daily driver
Old 07-18-2012, 10:24 AM   #13 (permalink)
Gregg, that's cool, but for another $20 you can get their entire distributor, which includes new bushings and pigtails, that's what I've been considering.
As for your rear end, it depends on what your current ratio is, you will only be able to go so low before you will need an overdrive and/or lock-up converter.
Old 07-18-2012, 12:18 PM   #14 (permalink)
Gears and stall make for huge seat of the pants improvements but how much you can stand with a 3speed tranny meaning no OD and no lockup.
Actual power production is all about airflow. HP is all about burning fuel at the right air fuel ratio, getting more fuel in the cylinders is easy, getting more air in the cylinders to burn it is the hard part.
Edelbrock parts are often a genuine improvement over the OLD stuff like what you had stock BUT at the same time there is a LOT of room for improvement on the old stuff and Edelbrock does not take you as far as it could for the effort involved.
I mean the cam is single pattern, for a naturally aspirated gen 1 or even gen 2 smallblock that is a joke, these engines have always been comparably stronger on the intake side than exhaust which is why you will find most cams for them have more exhaust duration.
I understand using Edelbrock matching stuff to simplify emissions inspection, but at the same time nobody can see a cam during inspection.
Heads are a HUGE part of the HP equation since all the airflow in and out goes through them, heads would be a good place to look BUT I would probably stay away from Edelbrock, well made products that do not actually offer as much gain as they could. This is not to say go the other end of the spectrum and look at AFR either, they are FAR more marketing than anything else. I think the Vortec suggestion is decent, they are inexpensive and a lot of shops all over the country know how to make them work even better.
Old 07-18-2012, 02:59 PM   #15 (permalink)
thanks. i'll keep that in mind.
Want to Do a L26 Performance Rebuild (Lookin for Suggestions) 1FasImp 7th Gen Engine Performance 28 10-16-2012 11:59 AM
any suggestions? Barfly Appearance 15 04-18-2011 07:49 PM
Performance increases for 03 impala w/ 3.8l 03impala03 Chevy Impala 7th Gen Discussion 8 09-14-2009 05:32 PM
Any suggestions? Benssjamin 6th Gen Suspension 4 06-25-2009 03:27 PM
suggestions Jam545 Wheels and Tires 8 03-20-2009 08:25 PM
