Big Block in a '63 - Chevy Impala Forums
Go Back   Chevy Impala Forums > Performance and Technical > Impala 1st - 5th Gen Discussion > 1st - 5th Gen Drivetrain
1st - 5th Gen Drivetrain Transmissions, clutches, and axles.
Old 06-24-2012, 09:07 AM   #1 (permalink)
kong1963's Avatar
Big Block in a '63
I want to put a 402 big block in my 63. anyone that can give me tips or their experiences doing this it would be greatly appreciated. donor motor is a 70 model and I have a m20 muncie for a tranny.
kong1963 is offline   Reply With Quote
Old 06-24-2012, 11:35 AM   #2 (permalink)
Storm Trooper Ralf
MixedImpala04's Avatar
Take lots of measurements and be prepared to fabricate custom mounts or buy the BB mounts and put them in. You may have to modify the trans tunnel a bit and that's it really. Everything else should fit in nicely
MixedImpala04 is offline   Reply With Quote
Old 06-24-2012, 09:11 PM   #3 (permalink)
Wheel Man's Avatar
Was it a small block car to begin with? If it was, the mounts will work, trans cross member will be in the right location. Drive shaft might need to be redone. Lots of parts available for your swap, get a nice rad so you don't have to worry about over heating.
1962 Biscayne 18's +20's-Coys,disks all around,power steering,Ididit column lowered and having fun
Wheel Man is offline   Reply With Quote
Old 09-01-2012, 01:34 PM   #4 (permalink)
62BillT's Avatar
It is actually a very easy swap. The biggest problem is exhaust and I went with Hooker Headers and custom made pipes.
Let me know if you need any details on it.
I put a 396 in a '62 back in '74.
Bill
62BillT is offline   Reply With Quote
Old 09-01-2012, 10:10 PM   #5 (permalink)
Liquor in the front, Poker in the back
blackimp's Avatar
Ya this is a cake walk for you, it will bolt right in and find a set of Hooker headers like stated above, one tube will wrap around the outside of the frame so that is why the come with a tube loose. I too did a swap in the early 70's a 396 into a 1960 sedan delivery with a glide. The biggest problem you will have is keeping a driveshaft center support bearing in the car, the big block tends to wreak havoc on them.
blackimp is offline   Reply With Quote
Old 09-05-2012, 11:42 AM   #6 (permalink)
darringer's Avatar
If it's a small block powerglide car, simple. Everything lines up. Even the driveshaft should be the same. Did the same thing with my 61. Went from a 350/powerglide to a 454/M20 4 speed. Assuming you have an auto trans, once the pedals are in, weld the Z-bar for the clutch linkage, and your set. Headers are the easy solution. I didn't like the Hooker Header setup, so I went with Sanderson Block Huggers. They fit great, stay inside the frame rails, and work with both 605 power steering and manual clutch linkage.
darringer is offline   Reply With Quote
Old 09-06-2012, 05:45 AM   #7 (permalink)
62BillT's Avatar
Looks good. Those Sanderson's look good too. They weren't available when I switched mine back in the mid 70's. We would also use the Powerglide Driveshaft in our 4-Speed swaps, but the Factory Specs are different. Some people say it shouldn't have worked, but we never had any problems. Check it close to be sure.
Bill
Chevrolet : Impala SS 409 Big Block No Reserve! 409 Big Block Dual Quad Chevy V8 Impa RSS Bot eBay Cars For Sale: Impala 0 05-22-2012 07:10 PM
Chevrolet : Caprice Big Block co Big Block co Coupe Numbers Matching 396 Automatic 19 RSS Bot eBay Cars For Sale: Caprice 0 12-10-2011 12:20 PM
Chevrolet : Caprice Big Block co Big Block 396 NUMBERS MATCHING NO RESERVE FRESH REBU RSS Bot eBay Cars For Sale: Caprice 0 11-11-2011 09:22 AM
Chevrolet : Caprice Big Block Big Block Coupe Numbers Matching 396 CLEAN TEXAS Car R RSS Bot eBay Cars For Sale: Caprice 0 10-29-2011 04:00 PM
Chevrolet : Caprice Big Block co Big Block Coupe Numbers Matching 396 CLEAN TEXAS Car RSS Bot eBay Cars For Sale: Caprice 0 10-29-2011 02:30 PM
