Go Back   Chevy Impala SS Forums > Performance and Technical Discussion > Impala 1st - 5th Gen Discussion > 1st - 5th Gen Drivetrain
Old 09-18-2007, 09:35 AM   #1 (permalink)
ROADMONARCH's Avatar
Replace Glass on 1968 Impala Custom
Hello,
Need to find out how to replace the door glass on a 1968 2 DR HT Impala Custom and if the Glass is Interchangeable with the Fastback.
Thanks,
Joe
ROAD MONARCHS
ROADMONARCH is offline
Sponsored links
Old 02-18-2008, 08:43 AM   #2 (permalink)
George's Avatar
The glass is held in by two bolts through the bottom of the glass, inside the door. Remove all the window cranks and door handles (need a special tool to remove the clips, you can get one at any parts store) and remove the arm rest. Then take the whole vinyl door panel off. Put the window crank back on without its clip and raise/lower window until you can see the bottom of the glass where the two bolts are. They will have large washers on them. Have a friend hold the glass while you remove them, or proceed very carefully. The glass should slide right out the top. As to whether or not the glass from a fastback will fit, I would call an auto glass place and see if they get the same part number for both cars.
George is offline
Sponsored links
vB code is On
eXTReMe Tracker
Sitemap Index - Archive
